Giving a Model-Based Testing Language a Formal Semantics via Partial MAX-SAT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Domain-specific Languages (DSLs) are widely used in model-based testing to make the benefits of modeling available to test engineers while avoiding the problem of excessive learning effort. Complex DSLs benefit from a formal definition of their semantics for model processing as well as consistency checking. A formal semantics can be established by mapping the model domain to a well-known formalism. In this paper, we present an industrial use case which includes a mapping from domain-specific models to Moore Machines, based on a Partial MAX-SAT problem, encoding a predicative semantics for the model-to-model mapping. We show how Partial MAX-SAT solves the frame problem for a non-trivial DSL in which the non-effect on variables cannot be determined statically. We evaluated the performance of our model-transformation algorithm based on models from our industrial use case.
497758_1_En_3_Chapter.pdf (425.4 Ko) Télécharger le fichier
hal-03239819 , version 1 (27-05-2021)
Paternité
Bernhard K. Aichernig, Christian Burghard. Giving a Model-Based Testing Language a Formal Semantics via Partial MAX-SAT. 32th IFIP International Conference on Testing Software and Systems (ICTSS), Dec 2020, Naples, Italy. pp.35-51, ⟨10.1007/978-3-030-64881-7_3⟩. ⟨hal-03239819⟩
32 Consultations
17 Téléchargements
