SGX-IR: Secure Information Retrieval with Trusted Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fahad Shaon
  • Fonction : Auteur
  • PersonId : 1022672
Murat Kantarcioglu
  • Fonction : Auteur
  • PersonId : 1010022
To preserve the security and the privacy of the data need for cloud applications, encrypting the data before outsourcing has emerged as an important tool. Furthermore, to enable efficient processing over the encrypted data stored in the cloud, utilizing efficient searchable symmetric encryption (SSE) schemes became popular. Usually, SSE schemes require an encrypted index to be built for efficient query processing. If the data owner has limited power, building this encrypted index before data is outsourced to the cloud could become a computational bottleneck. At the same time, secure outsourcing of encrypted index building using techniques such as homomorphic encryption is too costly for large data. Instead, in this work, we use a trusted processor, e.g, Intel Software Guard eXtension (SGX), to build a secure information retrieval system that provides better security guarantee and performance improvements. Unlike other related works, we focus on securely building the encrypted index in the cloud computing environment using the SGX, and show that the encrypted index could be used for executing keyword queries over text documents and face recognition detection in image documents. Finally, we show the effectiveness of our system via extensive empirical evaluation.
496047_1_En_21_Chapter.pdf (485.38 Ko) Télécharger le fichier
hal-03243643 , version 1 (31-05-2021)
Paternité
Fahad Shaon, Murat Kantarcioglu. SGX-IR: Secure Information Retrieval with Trusted Processors. 34th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jun 2020, Regensburg, Germany. pp.367-387, ⟨10.1007/978-3-030-49669-2_21⟩. ⟨hal-03243643⟩
55 Consultations
46 Téléchargements
