A Structured Latent Space for Human Body Motion Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a framework to learn a structured latent space to represent 4D human body motion, where each latent vector encodes a full motion of the whole 3D human shape. On one hand several data-driven skeletal animation models exist proposing motion spaces of temporally dense motion signals, but based on geometrically sparse kinematic representations. On the other hand many methods exist to build shape spaces of dense 3D geometry, but for static frames. We bring together both concepts, proposing a motion space that is dense both temporally and geometrically. Once trained, our model generates a multi-frame sequence of dense 3D meshes based on a single point in a low-dimensional latent space. This latent space is built to be structured, such that similar motions form clusters. It also embeds variations of duration in the latent vector, allowing semantically close sequences that differ only by temporal unfolding to share similar latent vectors. We demonstrate experimentally the structural properties of our latent space, and show it can be used to generate plausible interpolations between different actions. We also apply our model to 4D human motion completion, showing its promising abilities to learn spatio-temporal features of human motion. Code is available at https://github.com/mmarsot/A structured latent space.
A_structured_latent_space_for_human_body_motion_generation.pdf (6.03 Mo) Télécharger le fichier
hal-03250297 , version 1 (04-06-2021)
hal-03250297 , version 2 (10-06-2021)
hal-03250297 , version 3 (07-03-2022)
hal-03250297 , version 4 (07-09-2022)
  • HAL Id : hal-03250297 , version 3
Mathieu Marsot, Stefanie Wuhrer, Jean-Sébastien Franco, Stephane Durocher. A Structured Latent Space for Human Body Motion Generation. International Conference on 3D Vision (3DV), Sep 2022, Prague, Czech Republic. ⟨hal-03250297v3⟩
491 Consultations
326 Téléchargements
