Multi-shape registration with constrained deformations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Based on a Sub-Riemannian framework, deformation modules provide a way of building large diffeomorphic deformations satisfying a given geometrical structure. This allows to incorporate prior knowledge about object deformations into the model as a means of regularisation [10]. However, diffeomorphic deformations can lead to deceiving results if the deformed object is composed of several shapes which are close to each other but require drastically different deformations. For the related Large Deformation Diffemorphic Metric Mapping, which yields unstructured deformations, this issue was addressed in [2] introducing object boundary constraints. We develop a new registration problem, marrying the two frameworks to allow for different constrained deformations in different coupled shapes.
Modular_multi_shape.pdf (770.73 Ko) Télécharger le fichier
hal-03251766 , version 1 (07-06-2021)
hal-03251766 , version 2 (12-01-2022)
  • HAL Id : hal-03251766 , version 1
Rosa Kowalewski, Barbara Gris. Multi-shape registration with constrained deformations. GSI 2021 - 5th International Conference Geometric Science of Information, Jul 2021, Paris, France. pp.82-90. ⟨hal-03251766v1⟩
161 Consultations
144 Téléchargements
