Contribution of the world's main dust source regions to the global cycle of desert dust - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Atmospheric Chemistry and Physics Year : 2021
Abstract. Even though desert dust is the most abundant aerosol by mass in Earth's atmosphere, the relative contributions of the world's major source regions to the global dust cycle remain poorly constrained. This problem hinders accounting for the potentially large impact of regional differences in dust properties on clouds, the Earth's energy balance, and terrestrial and marine biogeochemical cycles. Here, we constrain the contribution of each of the world's main dust source regions to the global dust cycle. We use an analytical framework that integrates an ensemble of global aerosol model simulations with observationally informed constraints on the dust size distribution, extinction efficiency, and regional dust aerosol optical depth (DAOD). We obtain a dataset that constrains the relative contribution of nine major source regions to size-resolved dust emission, atmospheric loading, DAOD, concentration, and deposition flux. We find that the 22–29 Tg (1 standard error range) global loading of dust with a geometric diameter up to 20 µm is partitioned as follows: North African source regions contribute ∼ 50 % (11–15 Tg), Asian source regions contribute ∼ 40 % (8–13 Tg), and North American and Southern Hemisphere regions contribute ∼ 10 % (1.8–3.2 Tg). These results suggest that current models on average overestimate the contribution of North African sources to atmospheric dust loading at ∼ 65 %, while underestimating the contribution of Asian dust at ∼ 30 %. Our results further show that each source region's dust loading peaks in local spring and summer, which is partially driven by increased dust lifetime in those seasons. We also quantify the dust deposition flux to the Amazon rainforest to be ∼ 10 Tg yr−1, which is a factor of 2–3 less than inferred from satellite data by previous work that likely overestimated dust deposition by underestimating the dust mass extinction efficiency. The data obtained in this paper can be used to obtain improved constraints on dust impacts on clouds, climate, biogeochemical cycles, and other parts of the Earth system.
acp-21-8169-2021.pdf (8.2 Mo) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-03252769 , version 1 (07-06-2021)
Attribution
Identifiers
Cite
Jasper F Kok, Adeyemi A Adebiyi, Samuel Albani, Yves Balkanski, Ramiro Checa-Garcia, et al.. Contribution of the world's main dust source regions to the global cycle of desert dust. Atmospheric Chemistry and Physics, 2021, 21 (10), pp.8169 - 8193. ⟨10.5194/acp-21-8169-2021⟩. ⟨hal-03252769⟩
71 View
30 Download
Share
