The Central Valuations Monad - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We give a commutative valuations monad $\mathcal{Z}$ on the category DCPO of dcpo's and Scott-continuous functions. Compared to the commutative valuations monads given in [2], our new monad Z is larger and it contains all push-forward images of valuations on the unit interval [0, 1] along lower semi-continuous maps. We believe that this new monad will be useful in giving domain-theoretic denotational semantics for statistical programming languages with continuous probabilistic choice.
Cental-valuations.pdf (332.47 Ko) Télécharger le fichier
hal-03258065 , version 1 (11-06-2021)
hal-03258065 , version 2 (29-09-2021)
hal-03258065 , version 3 (02-12-2021)
  • HAL Id : hal-03258065 , version 1
Xiaodong Jia, Michael Mislove, Vladimir Zamdzhiev. The Central Valuations Monad. 2021. ⟨hal-03258065v1⟩
196 Consultations
176 Téléchargements
