Frost forecasting model using graph neural networks with spatio-temporal attention - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hernan Lira
  • Fonction : Auteur
  • PersonId : 1102200
Luis Martí
Nayat Sanchez-Pi
  • Fonction : Auteur
  • PersonId : 1102034
Frost forecast is an important issue in climate research because of its economic impact in several industries. In this study, a graph neural network (GNN) with spatio-temporal architecture is proposed to predict minimum temperatures in an experimental site. The model considers spatial and temporal relations and processes multiple time series simultaneously. Performing predictions of 6, 12, and 24 hrs this model outperforms statistical and non-graph deep learning models.
iclr2021_conference.pdf (1.61 Mo) Télécharger le fichier
hal-03259658 , version 1 (15-06-2021)
  • HAL Id : hal-03259658 , version 1
Hernan Lira, Luis Martí, Nayat Sanchez-Pi. Frost forecasting model using graph neural networks with spatio-temporal attention. AI: Modeling Oceans and Climate Change Workshop at ICLR 2021, Nayat Sanchez-Pi; Luis Martí, May 2021, Santiago, Chile. ⟨hal-03259658⟩
Collections
INRIA INRIA-CHILE
462 Consultations
517 Téléchargements
