Discrete potential mean field games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We propose and investigate a general class of discrete time and finite state space mean field game (MFG) problems with potential structure. Our model incorporates interactions through a congestion term and a price variable. It also allows hard constraints on the distribution of the agents. We analyze the connection between the MFG problem and two optimal control problems in duality. We present two families of numerical methods and detail their implementation: (i) primal-dual proximal methods (and their extension with nonlinear proximity operators), (ii) the alternating direction method of multipliers (ADMM) and a variant called ADM-G. We give some convergence results. Numerical results are provided for two examples with hard constraints.
discrete-potential-mfg.pdf (6.79 Mo) Télécharger le fichier
hal-03260057 , version 1 (14-06-2021)
hal-03260057 , version 2 (15-06-2021)
hal-03260057 , version 3 (06-03-2023)
  • HAL Id : hal-03260057 , version 1
Frédéric J Bonnans, Pierre Lavigne, Laurent Pfeiffer. Discrete potential mean field games. 2021. ⟨hal-03260057v1⟩
114 Consultations
112 Téléchargements
