Development of broadband high-frequency piezoelectric micromachined ultrasonic transducer array - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Sensors Année : 2021
Piezoelectric micromachined ultrasonic transducers (PMUT) are promising elements to fabricate a two-dimensional (2D) array with a pitch small enough (approximately half wavelength) to form and receive arbitrary acoustic beams for medical imaging. However, PMUT arrays have so far failed to combine the wide, high-frequency bandwidth needed to achieve a high axial resolution. In this paper, a polydimethylsiloxane (PDMS) backing structure is introduced into the PMUTs to improve the device bandwidth while keeping a sub-wavelength (λ) pitch. We implement this backing on a 16 × 8 array with 75 µm pitch (3λ/4) with a 15 MHz working frequency. Adding the backing nearly doubles the bandwidth to 92% (−6 dB) and has little influence on the impulse response sensitivity. By widening the transducer bandwidth, this backing may enable using PMUT ultrasonic arrays for high-resolution 3D imaging.
JiaZhou_Sensors-21_5-01823.pdf (2.98 Mo) Télécharger le fichier
hal-03260141 , version 1 (14-06-2021)
Paternité
Xu-Bo Wang, Le-Ming He, You-Cao Ma, Wen-Juan Liu, Wei-Jiang Xu, et al.. Development of broadband high-frequency piezoelectric micromachined ultrasonic transducer array. Sensors, 2021, 21 (5), pp.1823. ⟨10.3390/s21051823⟩. ⟨hal-03260141⟩
93 Consultations
132 Téléchargements
