A machine learning approach to screen for preclinical Alzheimer's disease - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurobiology of Aging Année : 2021
Combining multimodal biomarkers could help in the early diagnosis of Alzheimer's disease (AD). We included 304 cognitively normal individuals from the INSIGHT-preAD cohort. Amyloid and neurodegeneration were assessed on 18F-florbetapir and 18F-fluorodeoxyglucose PET, respectively. We used a nested cross-validation approach with non-invasive features (electroencephalography [EEG], APOE4 genotype, demographic, neuropsychological and MRI data) to predict: 1/ amyloid status; 2/ neurodegeneration status; 3/ decline to prodromal AD at 5-year follow-up. Importantly, EEG was most strongly predictive of neurodegeneration, even when reducing the number of channels from 224 down to 4, as 4-channel EEG best predicted neurodegeneration (negative predictive value [NPV] = 82%, positive predictive value [PPV] = 38%, 77% specificity, 45% sensitivity). The combination of demographic, neuropsychological data, APOE4 and hippocampal volumetry most strongly predicted amyloid (80% NPV, 41% PPV, 70% specificity, 58% sensitivity) and most strongly predicted decline to prodromal AD at 5 years (97% NPV, 14% PPV, 83% specificity, 50% sensitivity). Thus, machine learning can help to screen patients at high risk of preclinical AD using non-invasive and affordable biomarkers.
Gaubert et al. - 2021 - A machine learning approach to screen for preclini.pdf (630.17 Ko) Télécharger le fichier
hal-03261206 , version 1 (15-06-2021)
Sinead Gaubert, Marion Houot, Federico Raimondo, Manon Ansart, Marie-Constance Corsi, et al.. A machine learning approach to screen for preclinical Alzheimer's disease. Neurobiology of Aging, 2021, 105, pp.205-216. ⟨10.1016/j.neurobiolaging.2021.04.024⟩. ⟨hal-03261206⟩
220 Consultations
202 Téléchargements
