New interface
Journal articles
PPalign: optimal alignment of Potts models representing proteins with direct coupling information
Hugo Talibart 1 François Coste 1
1 Dyliss - Dynamics, Logics and Inference for biological Systems and Sequences
Inria Rennes – Bretagne Atlantique , IRISA-D7 - GESTION DES DONNÉES ET DE LA CONNAISSANCE
Abstract : Background To assign structural and functional annotations to the ever increasing amount of sequenced proteins, the main approach relies on sequence-based homology search methods, e.g. BLAST or the current state-of-the-art methods based on profile Hidden Markov Models, which rely on significant alignments of query sequences to annotated proteins or protein families. While powerful, these approaches do not take coevolution between residues into account. Taking advantage of recent advances in the field of contact prediction, we propose here to represent proteins by Potts models, which model direct couplings between positions in addition to positional composition, and to compare proteins by aligning these models. Due to non-local dependencies, the problem of aligning Potts models is hard and remains the main computational bottleneck for their use. MethodsWe introduce here an Integer Linear Programming formulation of the problem and PPalign, a program based on this formulation, to compute the optimal pairwise alignment of Potts models representing proteins in tractable time. The approach is assessed with respect to a non-redundant set of reference pairwise sequence alignments from SISYPHUS benchmark which have lowest sequence identity (between 3% and 20% ) and enable to build reliable Potts models for each sequence to be aligned. This experimentation confirms that Potts models can be aligned in reasonable time ( 1 ′ 37 ′ ′ in average on these alignments). The contribution of couplings is evaluated in comparison with HHalign and independent-site PPalign. Although Potts models were not fully optimized for alignment purposes and simple gap scores were used, PPalign yields a better mean F 1 score and finds significantly better alignments than HHalign and PPalign without couplings in some cases. ConclusionsThese results show that pairwise couplings from protein Potts models can be used to improve the alignment of remotely related protein sequences in tractable time. Our experimentation suggests yet that new research on the inference of Potts models is now needed to make them more comparable and suitable for homology search. We think that PPalign’s guaranteed optimality will be a powerful asset to perform unbiased investigations in this direction.
Complete list of metadata
https://hal.inria.fr/hal-03264248
Contributor : Admin HAL UR1 Connect in order to contact the contributor
Submitted on : Friday, May 6, 2022 - 2:01:24 PM
Last modification on : Friday, August 5, 2022 - 2:54:52 PM
File
s12859-021-04222-4
Publisher files allowed on an open archive
Identifiers
Citation
Hugo Talibart, François Coste. PPalign: optimal alignment of Potts models representing proteins with direct coupling information. BMC Bioinformatics, 2021, 22 (317), pp.1-22. ⟨10.1186/s12859-021-04222-4⟩. ⟨hal-03264248v2⟩
Share
Metrics
Record views
149
Files downloads
8
