Analysis of the implicit Euler time-discretization of a class of descriptor-variable linear cone complementarity systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Convex Analysis Année : 2022
This article is largely concerned with the time-discretization of a class of descriptor-variable systems coupled with complementarity constraints, named descriptor-variable linear complementarity systems (DVLCS). Specifically, the Euler implicit discretization of DVLCS is analysed: the one-step non-smooth problem, which is a generalized equation, is shown to be well-posed under some conditions. Then the convergence of the discretized solutions is studied, and the existence of solutions to the continuous-time system is shown as a consequence. Several circuits examples illustrate the applicability and the theoretical developments.
MLCS1.pdf (377.13 Ko) Télécharger le fichier
hal-03264720 , version 1 (18-06-2021)
hal-03264720 , version 2 (24-01-2024)
Paternité
  • HAL Id : hal-03264720 , version 2
Bernard Brogliato. Analysis of the implicit Euler time-discretization of a class of descriptor-variable linear cone complementarity systems. Journal of Convex Analysis, 2022, 29 (2), pp.481-517. ⟨hal-03264720v2⟩
114 Consultations
144 Téléchargements
