Application of a biological multilevel response approach in the copepod Acartia tonsa for toxicity testing of three oil Water Accommodated Fractions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Marine Environmental Research Année : 2021
Tamer Hafez
  • Fonction : Auteur
  • PersonId : 1102561
Dennis Bilbao
  • Fonction : Auteur
  • PersonId : 1102562
Nestor Etxebarria
  • Fonction : Auteur
  • PersonId : 1102563
Copepods play a critical role in the marine food webs, being a food source for marine organisms. In this study, we investigated the toxic effects of Water Accommodated Fractions (WAFs) from three types of oil: Naphthenic North Sea crude oil (NNS), Intermediate Fuel Oil (IFO 180) and a commercial Marine Gas Oil (MGO). The WAFs were prepared at 10 • C and 30 PSU (practical salinity unit), and tested on the marine copepod Acartia tonsa at different endpoints and at different levels of biological organization. We determined the median lethal concentrations after 96 h (LC50) and reproduction capabilities were calculated in adult females following seven days of exposure to sublethal WAF doses. The total lipid content was measured in reproductive females using Nile red lipophilic dye after 96 h of WAF exposure. We also measured the transcription levels of genes involved in antioxidant response and xenobiotic biotransformation after short exposure for 48 h. High doses (7% WAF) of MGO affected survival, percentage of fecund females, egg hatching success, and total lipid content. The IFO 180 WAF affected, at medium (20%) and high (40%) doses, the number of fecund females, mortality and produced significant effects on gene expression levels. In conclusion, toxicity assays showed that the WAFs prepared from refined oils were more toxic than crude oil WAF to Acartia tonsa.
1-s2.0-S0141113621001343-main.pdf (3.47 Mo) Télécharger le fichier
hal-03265401 , version 1 (20-06-2021)
Tamer Hafez, Dennis Bilbao, Nestor Etxebarria, Robert Duran, Maren Ortiz-Zarragoitia. Application of a biological multilevel response approach in the copepod Acartia tonsa for toxicity testing of three oil Water Accommodated Fractions. Marine Environmental Research, 2021, 169, pp.105378. ⟨10.1016/j.marenvres.2021.105378⟩. ⟨hal-03265401⟩
74 Consultations
85 Téléchargements
