A New Approach to Determine the Optimal Number of Clusters Based on the Gap Statistic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jaekyung Yang
  • Fonction : Auteur
  • PersonId : 1102767
Myoungjin Choi
  • Fonction : Auteur
Data clustering is one of the most important unsupervised classification method. It aims at organizing objects into groups (or clusters), in such a way that members in the same cluster are similar in some way and members belonging to different cluster are distinctive. Among other general clustering method, k-means is arguably the most popular one. However, it still has some inherent weaknesses. One of the biggest challenges when using k-means is to determine the optimal number of clusters, k. Although many approaches have been suggested in the literature, this is still considered as an unsolved problem. In this study, we propose a new technique to improve the gap statistic approach for selecting k. It has been tested on different datasets, on which it yields superior results compared to the original gap statistic. We expect our new method to also work well on other clustering algorithms where the number k is required. This is because our new approach, like the gap statistic, can work with any clustering method.
487577_1_En_15_Chapter.pdf (442.29 Ko) Télécharger le fichier
hal-03266454 , version 1 (21-06-2021)
Paternité
Jaekyung Yang, Jong-Yeong Lee, Myoungjin Choi, Yeongin Joo. A New Approach to Determine the Optimal Number of Clusters Based on the Gap Statistic. 2nd International Conference on Machine Learning for Networking (MLN), Dec 2019, Paris, France. pp.227-239, ⟨10.1007/978-3-030-45778-5_15⟩. ⟨hal-03266454⟩
62 Consultations
207 Téléchargements
