Quantitative comparison of geological data and model simulations constrains early Cambrian geography and climate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Communications Année : 2021
Marine ecosystems with a diverse range of animal groups became established during the early Cambrian (~541 to~509 Ma). However, Earth's environmental parameters and palaeogeography in this interval of major macro-evolutionary change remain poorly constrained. Here, we test contrasting hypotheses of continental configuration and climate that have profound implications for interpreting Cambrian environmental proxies. We integrate general circulation models and geological observations to test three variants of the 'Antarctocentric' paradigm, with a southern polar continent, and an 'equatorial' configuration that lacks polar continents. This quantitative framework can be applied to other deep-time intervals when environmental proxy data are scarce. Our results show that the Antarctocentric palaeogeographic paradigm can reconcile geological data and simulated Cambrian climate. Our analyses indicate a greenhouse climate during the Cambrian animal radiation, with mean annual sea-surface temperatures between~9°C to~19°C and~30°C to~38°C for polar and tropical palaeolatitudes, respectively.
s41467-021-24141-5.pdf (2.74 Mo) Télécharger le fichier
hal-03273912 , version 1 (29-06-2021)
Paternité
Thomas W Wong Hearing, Alexandre Pohl, Mark Williams, Yannick Donnadieu, Thomas H P Harvey, et al.. Quantitative comparison of geological data and model simulations constrains early Cambrian geography and climate. Nature Communications, 2021, 12, ⟨10.1038/s41467-021-24141-5⟩. ⟨hal-03273912⟩
147 Consultations
48 Téléchargements
