Reasoning about Java Programs with Aliasing and Frame Conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Claude Marché
Christine Paulin-Mohring
  • Fonction : Auteur
  • PersonId : 864666
Several tools exist for reasoning about Java programs annotated with JML specifications. A main issue is to deal with possible aliasing between objects and to handle correctly the frame conditions limiting the part of memory that a method is allowed to modify. Tools designed for automatic use (like ESC/Java) are not complete and even not necessarily correct. On the other side, tools which offer a full modeling of the program require a heavy user interaction for discharging proof obligations. In this paper, we present the modeling of Java programs used in the Krakatoa tool, which generates proof obligations expressed in a logic language suitable for both automatic and interactive reasoning. Using the Simplify automatic theorem prover, we are able to establish automatically more properties than static analysis tools, with a method which is guaranteed to be sound, assuming only the correctness of our logical interpretation of programs and specifications.
marche05tphols.pdf (194.51 Ko) Télécharger le fichier
hal-03274993 , version 1 (30-06-2021)
Claude Marché, Christine Paulin-Mohring. Reasoning about Java Programs with Aliasing and Frame Conditions. Theorem Proving in Higher Order Logics, 2005, Oxford, United Kingdom. pp.179-194, ⟨10.1007/11541868_12⟩. ⟨hal-03274993⟩
34 Consultations
58 Téléchargements
