Coherent presentations of a class of monoids admitting a Garside family - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
This paper shows how to construct coherent presentations of a class of monoids, including left-cancellative noetherian monoids containing no nontrivial invertible element and admitting a Garside family. Thereby, it resolves the question of finding a unifying generalisation of the following two distinct extensions of Deligne's original construction of coherent presentations for spherical Artin-Tits monoids: to general Artin-Tits monoids, and to Garside monoids. The result is applied to a dual braid monoid, and to some monoids which are neither Artin-Tits nor Garside. For the Artin-Tits monoid of type $\widetilde{A}_{2}$, a finite coherent presentation is given, having a finite Garside family as a generating set.
coherent.pdf (700.89 Ko) Télécharger le fichier
hal-03276119 , version 1 (01-07-2021)
hal-03276119 , version 2 (29-07-2022)
hal-03276119 , version 3 (06-12-2022)
hal-03276119 , version 4 (28-02-2023)
  • HAL Id : hal-03276119 , version 1
Pierre-Louis Curien, Alen Ðurić, Yves Guiraud. Coherent presentations of a class of monoids admitting a Garside family. 2021. ⟨hal-03276119v1⟩
132 Consultations
66 Téléchargements
