Degenerate processes killed at the boundary of a domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We investigate certain properties of degenerate Feller processes that are killed when exiting a relatively compact set. Our main result provides general conditions ensuring that such a process possesses a (possibly non unique) quasi stationary distribution. Conditions ensuring uniqueness and exponential convergence are discussed. The results are applied to stochastic dierential equations.
KilledProcessesVI.pdf (261.13 Ko) Télécharger le fichier
hal-03278551 , version 1 (05-07-2021)
Paternité
Michel Benaïm, Nicolas Champagnat, William Oçafrain, Denis Villemonais. Degenerate processes killed at the boundary of a domain. 2021. ⟨hal-03278551⟩
42 Consultations
82 Téléchargements
