FMHex20: An earthquake focal mechanism database for seismotectonic analyses in metropolitan France and bordering regions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bulletin de la Société Géologique de France Année : 2021
Stephane Mazzotti
Bertrand Delouis
Cécile Doubre
Maxime Godano
Christophe Larroque
We present a compilation of over 1700 focal mechanisms for nearly 1300 earthquakes in metropolitan France and bordering regions of Western Europe. It is based on both published and unpublished sources (articles, reports, observatory websites) for which the focal mechanism solutions have been verified for internal consistency, corrected in cases of minor errors and rejected in cases of major inconsistencies between the parameters. The database, labeled FMHex20, is a first version and should be regularly updated in the future as part of an ongoing effort within the Seismicity Transverse Action of the French Résif research infrastructure. We also present first-order seismotectonic analyses for the whole metropolitan France and for two regions (Western France and Northern Alps-Jura-Vosges) to illustrate how the FMHex20 database can serve as a basis for geodynamic or seismic hazard zonation studies. Combined with complementary datasets, it can improve our understanding of the kinematics of potentially active faults, including in very-low-strain-rate regions as is the case for most of France.
Tectonique
bsgf200013.pdf (8.61 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03278811 , version 1 (08-07-2021)
Paternité
Stephane Mazzotti, Clémence Aubagnac, Laurent Bollinger, Karla Coca Oscanoa, Bertrand Delouis, et al.. FMHex20: An earthquake focal mechanism database for seismotectonic analyses in metropolitan France and bordering regions. Bulletin de la Société Géologique de France, 2021, 192, pp.10. ⟨10.1051/bsgf/2020049⟩. ⟨hal-03278811⟩
114 Consultations
129 Téléchargements
