Quantification and reduction of uncertainties in a wind turbine numerical model based on global sensitivity analysis and recursive Bayesian inference approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
A framework to perform quantification and reduction of uncertainties in a wind turbine numerical model using global sensitivity analysis and recursive Bayesian inference method is developed in this paper. We explain how a prior probability distribution on the model parameters is transformed into a posterior probability distribution, by incorporating a physical model and real field noisy observations. Nevertheless, these approaches suffer from the so-called curse of dimensionality. In order to reduce the dimension, Sobol' indices approach for global sensitivity analysis, in the context of wind turbine modelling, is presented. A major issue arising for such inverse problems is identifiabil-ity, i.e. whether the observations are sufficient to unambiguously determine the input parameters that generated the observations. Hereafter, global sensitivity analysis is also used in the context of identifiability.
Preprint_Hirvoas.pdf (817.1 Ko) Télécharger le fichier
hal-03279947 , version 1 (22-06-2020)
hal-03279947 , version 3 (06-07-2021)
  • HAL Id : hal-03279947 , version 1
Adrien Hirvoas, Clémentine Prieur, Élise Arnaud, Fabien Caleyron, Miguel Munoz Zuniga. Quantification and reduction of uncertainties in a wind turbine numerical model based on global sensitivity analysis and recursive Bayesian inference approach. 2020. ⟨hal-03279947v1⟩
443 Consultations
488 Téléchargements
