Construction and analysis of discretization schemes for one-dimensional nonlocal Schrödinger equations with exact absorbing boundary conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The construction of exact absorbing boundary conditions (ABCs) for the one-dimensional nonlocal fully-discrete Schrödinger equation is proposed. The computation of the Green's functions for the discrete nonlocal Schrödinger equation is stated and used to build the ABCs. Numerical error estimates are then proved for the case of a singular interaction kernel. The theory and numerical analysis is supported by numerical examples.
nonlocalSchrodingerShorten.pdf (671.3 Ko) Télécharger le fichier
hal-03281252 , version 1 (08-07-2021)
  • HAL Id : hal-03281252 , version 1
Gang Pang, Songsong Ji, Xavier Antoine. Construction and analysis of discretization schemes for one-dimensional nonlocal Schrödinger equations with exact absorbing boundary conditions. 2021. ⟨hal-03281252⟩
38 Consultations
60 Téléchargements
