A Formal Framework for Consent Management
The aim of this work is to design a formal framework for consent management in line with EU’s General Data Protection Regulation (GDPR). To make a general solution, we consider a high-level modeling language for distributed service-oriented systems, building on the paradigm of active objects. Our framework provides a general solution for data subjects to observe and change their privacy settings and to be informed about all personal data stored about them. The solution consists of a set of predefined types for privacy related concepts, a formalization of policy compliance, a set of interfaces that forms the basis of interaction with external users for consent management, a set of classes that is used in interaction with the runtime system, and a runtime system enforcing the consented policies.
