DMS and MultiGLODS: Black-Box Optimization Benchmarking of Two Direct Search Methods on the bbob-biobj Test Suite - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dimo Brockhoff
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Direct Multisearch (DMS) and MultiGLODS are two derivative-free solvers for approximating the entire set of Pareto-optimal solutions of a multiobjective (blackbox) problem. They both follow the search/poll step approach of direct search methods, employ Pareto dominance to avoid aggregating objectives, and have theoretical limit guarantees. Although the original publications already compare the two algorithms empirically with a variety of multiobjective solvers, an analysis on their scaling behavior with dimension was missing. Here, we run the publicly available implementations on the bbob-biobj test suite of the COCO platform and by investigating their performances in more detail, observe (i) a small defect in the default initialization of DMS, (ii) for both algorithms a decrease in relative performance to other algorithms of the original studies (even matching the performance of random search for MultiGLODS in higher dimension), and (iii) consequently, an under-performance to previously untested stochastic solvers from the evolutionary computation field, especially when the dimension is higher.
DMS-MultiGLODS-BIOBJmultiple-submitted.pdf (1.79 Mo) Télécharger le fichier
hal-03284476 , version 1 (12-07-2021)
Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
Dimo Brockhoff, Baptiste Plaquevent-Jourdain, Anne Auger, Nikolaus Hansen. DMS and MultiGLODS: Black-Box Optimization Benchmarking of Two Direct Search Methods on the bbob-biobj Test Suite. GECCO 2021 Companion - Genetic and Evolutionary Computation Conference Companion, Jul 2021, Lille / Virtual, France. pp.8, ⟨10.1145/3449726.3463207⟩. ⟨hal-03284476⟩
58 Consultations
152 Téléchargements
