A Measure Theoretical Approach to the Mean-field Maximum Principle for Training NeurODEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this paper we consider a measure-theoretical formulation of the training of NeurODEs in the form of a mean-field optimal control with L 2-regularization of the control. We derive first order optimality conditions for the NeurODE training problem in the form of a mean-field maximum principle, and show that it admits a unique control solution, which is Lipschitz continuous in time. As a consequence of this uniqueness property, the mean-field maximum principle also provides a strong quantitative generalization error for finite sample approximations. Our derivation of the mean-field maximum principle is much simpler than the ones currently available in the literature for mean-field optimal control problems, and is based on a generalized Lagrange multiplier theorem on convex sets of spaces of measures. The latter is also new, and can be considered as a result of independent interest.
Mean field control.pdf (660.97 Ko) Télécharger le fichier
hal-03289521 , version 1 (17-07-2021)
hal-03289521 , version 2 (17-10-2023)
  • HAL Id : hal-03289521 , version 1
Benoît Bonnet, Cristina Cipriani, Massimo Fornasier, Hui Huang. A Measure Theoretical Approach to the Mean-field Maximum Principle for Training NeurODEs. 2021. ⟨hal-03289521v1⟩
99 Consultations
102 Téléchargements
