The generic multiplicity-induced-dominancy property from retarded to neutral delay-differential equations: When delay-systems characteristics meet the zeros of Kummer functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this paper, which is a direct continuation and generalization of the recent works by the authors [https://doi.org/10.1051/cocv/2019073, https://doi.org/10.1016/j.jde.2021.03.003], we show the validity of the generic multiplicity-induced-dominancy property for a general class of linear functional differential equations with a single delay, including the retarded as well as the neutral cases. The result is based on an appropriate integral representation of the corresponding characteristic quasipolynomial functions involving some appropriate degenerate hypergeometric functions.
MID_GENERAL.pdf (560.21 Ko) Télécharger le fichier
hal-03298718 , version 1 (23-07-2021)
hal-03298718 , version 2 (29-10-2021)
  • HAL Id : hal-03298718 , version 1
Islam Boussaada, Guilherme Mazanti, Silviu-Iulian Niculescu. The generic multiplicity-induced-dominancy property from retarded to neutral delay-differential equations: When delay-systems characteristics meet the zeros of Kummer functions. 2021. ⟨hal-03298718v1⟩
278 Consultations
197 Téléchargements
