A Layered Debris Disk around M Star TWA 7 in Scattered Light - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Astrophysical Journal Année : 2021
We have obtained Hubble Space Telescope (HST) coronagraphic observations of the circumstellar disk around M star TWA 7 using the Space Telescope Imaging Spectrograph (STIS) instrument in visible light. Together with archival observations, including HST/NICMOS using the F160W filter and Very Large Telescope/SPHERE at the H-band in polarized light, we investigate the system in scattered light. By studying this nearly face-on system using geometric disk models and Henyey-Greenstein phase functions, we report a new discovery of a tertiary ring and a clump. We identify a layered architecture: three rings, a spiral, and an ≈150 au 2 elliptical clump. The most extended ring peaks at 28 au, and the other components are on its outskirts. Our point-source detection-limit calculations demonstrate the necessity of disk modeling in imaging fainter planets. Morphologically, we witness a clockwise spiral motion, and the motion pattern is consistent with both solid body motion and local Keplerian motion; we also observe underdensity regions for the secondary ring that might result from mean-motion resonance or moving shadows: both call for re-observations to determine their nature. Comparing multi-instrument observations, we obtain blue STIS-NICMOS color, a STIS-SPHERE radial distribution peak difference for the tertiary ring, and a high SPHERE-NICMOS polarization fraction; these aspects indicate that TWA 7 could retain small dust particles. By viewing the debris disk around M star TWA 7 at a nearly face-on vantage point, our study allows for the understanding of such disks in scattered light in both system architecture and dust property.
2105.09949.pdf (4.12 Mo) Télécharger le fichier
hal-03304881 , version 1 (28-07-2021)
Bin Ren, Élodie Choquet, Marshall D Perrin, Dimitri Mawet, Christine H Chen, et al.. A Layered Debris Disk around M Star TWA 7 in Scattered Light. The Astrophysical Journal, 2021, 914 (2), pp.95. ⟨10.3847/1538-4357/ac03b9⟩. ⟨hal-03304881⟩
42 Consultations
32 Téléchargements
