On a structure-preserving numerical method for fractional Fokker-Planck equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2023
In this paper, we introduce and analyse numerical schemes for the homogeneous and the kinetic Lévy-Fokker-Planck equation. The discretizations are designed to preserve the main features of the continuous model such as conservation of mass, heavy-tailed equilibrium and (hypo)coercivity properties. We perform a thorough analysis of the numerical scheme and show exponential stability and convergence of the scheme. Along the way, we introduce new tools of discrete functional analysis, such as discrete nonlocal Poincaré and interpolation inequalities adapted to fractional diffusion. Our theoretical findings are illustrated and complemented with numerical simulations..
paper-acc.pdf (794.55 Ko) Télécharger le fichier
hal-03305165 , version 1 (28-07-2021)
hal-03305165 , version 2 (23-07-2022)
Nathalie Ayi, Maxime Herda, Hélène Hivert, Isabelle Tristani. On a structure-preserving numerical method for fractional Fokker-Planck equations. Mathematics of Computation, 2023, 92 (340), pp.635--693. ⟨10.1090/mcom/3789⟩. ⟨hal-03305165v2⟩
218 Consultations
107 Téléchargements
