Accessibility Properties of Abnormal Geodesics in Optimal Control Illustrated by Two Case Studies. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this article, we use two case studies from geometry and optimal control of chemical network to analyze the relation between abnormal geodesics in time optimal control, accessibility properties and regularity of the time minimal value function.
zermelo_2022.pdf (1.39 Mo) Télécharger le fichier
hal-03310348 , version 1 (30-07-2021)
hal-03310348 , version 2 (23-02-2022)
hal-03310348 , version 3 (29-04-2022)
hal-03310348 , version 4 (22-03-2023)
hal-03310348 , version 5 (03-10-2023)
  • HAL Id : hal-03310348 , version 2
Bernard Bonnard, Jérémy Rouot, Boris Wembe. Accessibility Properties of Abnormal Geodesics in Optimal Control Illustrated by Two Case Studies.. 2022. ⟨hal-03310348v2⟩
464 Consultations
282 Téléchargements
