VOCs are relevant biomarkers of elicitor-induced defences in grapevine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Molecules Année : 2021
Grapevine is susceptible to fungal diseases generally controlled by numerous chemical fungicides. Elicitors of plant defence are a way of reducing the use of these chemicals, but still provide inconsistent efficiency. Easy-to-analyse markers of grapevine responses to elicitors are needed to determine the best conditions for their efficiency and position them in protection strategies. We previously reported that the elicitor sulphated laminarin induced the emission of volatile organic compounds (VOCs) by grapevine leaves. The present study was conducted to characterise and compare VOC emissions in response to other elicitors. Bastid was first used to test the conditions of VOC collection and analysis. Using SBSE-GC-MS, we detected several VOCs, including the sesquiterpene alpha-farnesene, in a time-dependent manner. This was correlated with the induction of farnesene synthase gene expression, in parallel with stilbene synthesis (another defence response), and associated to resistance against downy mildew. The other elicitors (Redeli, Romeo, Bion, chitosan, and an oligogalacturonide) induced VOC emission, but with qualitative and quantitative differences. VOC emission thus constitutes a response of grapevine to elicitors of various chemical structures. Therefore, VOC analysis is relevant for studying the impact of environmental factors on grapevine defence responses and optimising the performance of elicitors in vineyards.
2021_Lemaitre-Guillier_molecules.pdf (2.39 Mo) Télécharger le fichier
hal-03311901 , version 1 (02-08-2021)
Paternité
Christelle Lemaitre-Guillier, Christelle Dufresne, Agnes Chartier, Stéphanie Cluzet, Josep Valls, et al.. VOCs are relevant biomarkers of elicitor-induced defences in grapevine. Molecules, 2021, 26 (14), pp.1-18. ⟨10.3390/molecules26144258⟩. ⟨hal-03311901⟩
88 Consultations
66 Téléchargements
