On energetically optimal finite-time stabilization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of finite-time stabilization of a linear plant with an optimization of both a settling time and an weighted/averaged control energy is studied using the concept of generalized homogeneity. It is shown that the optimal finite-time stabilizing control in this case can be designed solving a simple linear algebraic equation. Some issues of a practical applicability and a robustness of the obtained control law are studied.
Automatique
main.pdf (534.55 Ko) Télécharger le fichier
hal-03313472 , version 1 (04-08-2021)
  • HAL Id : hal-03313472 , version 1
Andrey Polyakov, Denis Efimov, Xubin Ping. On energetically optimal finite-time stabilization. IEEE Conference on Decision and Control, Dec 2021, Austin, United States. ⟨hal-03313472⟩
81 Consultations
159 Téléchargements
