Equivalence of Linear Complementarity Problems: Theory and Application to Nonsmooth Bifurcations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Linear complementarity problems provide a powerful framework to model nonsmooth phenomena in a variety of real-world applications. In dynamical control systems, they appear coupled to a linear input-output system in the form of linear complementarity systems. Mimicking the program that led to the foundation of bifurcation theory in smooth maps, we introduce a novel notion of equivalence between linear complementarity problems that sets the basis for a theory of bifurcations in a large class of nonsmooth maps, including, but not restricted to, steadystate bifurcations in linear complementarity systems. Our definition exploits the rich geometry of linear complementarity problems and leads to constructive algebraic conditions for identifying and classifying the nonsmooth singularities associated with nonsmooth bifurcations. We thoroughly illustrate our theory on an extended applied example, the design of bistability in an electrical network, and a more theoretical one, the identification and classification of all possible equivalence classes in two-dimensional linear complementarity problems.
main.pdf (362.95 Ko) Télécharger le fichier
hal-03319638 , version 1 (13-08-2021)
hal-03319638 , version 2 (21-03-2023)
Felix Miranda-Villatoro, Fernando Castaños, Alessio Franci. Equivalence of Linear Complementarity Problems: Theory and Application to Nonsmooth Bifurcations. 2021. ⟨hal-03319638v1⟩
98 Consultations
219 Téléchargements
