A proof of the Multiplicative 1-2-3 Conjecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
We prove that the product version of the 1-2-3 Conjecture, raised by Skowronek-Kaziów in 2012, is true. Namely, for every connected graph with order at least 3, we prove that we can assign labels 1,2,3 to the edges in such a way that no two adjacent vertices are incident to the same product of labels.
proof123p.pdf (372.61 Ko) Télécharger le fichier
hal-03324458 , version 1 (23-08-2021)
hal-03324458 , version 2 (16-05-2022)
Julien Bensmail, Hervé Hocquard, Dimitri Lajou, Éric Sopena. A proof of the Multiplicative 1-2-3 Conjecture. [Research Report] Université côte d'azur; Université de bordeaux. 2021. ⟨hal-03324458v1⟩
71 Consultations
49 Téléchargements
