Semi-device-independent Certification of Causal Nonseparability with Trusted Quantum Inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2022
While the standard formulation of quantum theory assumes a fixed background causal structure, one can relax this assumption within the so-called process matrix framework. Remarkably, some processes, termed causally nonseparable, are incompatible with a definite causal order. We explore a form of certification of causal nonseparability in a semi-device-independent scenario where the involved parties receive trusted quantum inputs, but whose operations are otherwise uncharacterised. Defining the notion of causally nonseparable distributed measurements, we show that certain causally nonseparable processes which cannot violate any causal inequality, such as the canonical example of the quantum switch, can generate noncausal correlations in such a scenario. Moreover, by further imposing some natural structure to the untrusted operations, we show that all bipartite causally nonseparable process matrices can be certified with trusted quantum inputs.
2107.10877.pdf (1016.14 Ko) Télécharger le fichier
hal-03330393 , version 1 (31-08-2021)
hal-03330393 , version 2 (30-08-2022)
Hippolyte Dourdent, Alastair A. Abbott, Nicolas Brunner, Ivan Šupić, Cyril Branciard. Semi-device-independent Certification of Causal Nonseparability with Trusted Quantum Inputs. Physical Review Letters, 2022, 129 (9), pp.090402. ⟨10.1103/PhysRevLett.129.090402⟩. ⟨hal-03330393v1⟩
126 Consultations
107 Téléchargements
