A survey of the main fundamental European trigonometric tables printed in the 15th and 16th centuries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
This document is a survey of the main European fundamental trigonometric tables printed in the 15th and 16th centuries. After a review of the work done before the 15th century in Greece, India and the Arab world, the starting points in Europe are examined. The seminal work of Regiomontanus is carefully studied and the lineage of all later works is established.
roegel2021early-european-tables.pdf (22.56 Mo) Télécharger le fichier
roegel2021regio10.pdf (345.39 Ko) Télécharger le fichier
roegel2021regio6.pdf (345.13 Ko) Télécharger le fichier
hal-03330572 , version 1 (01-09-2021)
  • HAL Id : hal-03330572 , version 1
Denis Roegel. A survey of the main fundamental European trigonometric tables printed in the 15th and 16th centuries. [Research Report] LORIA (Université de Lorraine, CNRS, INRIA). 2021. ⟨hal-03330572⟩
117 Consultations
36 Téléchargements
