A reconstruction of Johannes Engel's table of sines in Regiomontanus's <i>Tabulæ directionum profectionumque</i> (1504) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
A reconstruction of Johannes Engel's table of sines in Regiomontanus's Tabulæ directionum profectionumque (1504)
This document gives a modern reconstruction of Johannes Engel (1453-1512)'s table of sines, first published in 1490, but here based on the 1504 edition. Engel's table is itself based on Regiomontanus (1436-1476) table of sines.
regiomontanus-engel1504tabulae-doc.pdf (769.2 Ko) Télécharger le fichier
hal-03330579 , version 1 (01-09-2021)
  • HAL Id : hal-03330579 , version 1
Denis Roegel. A reconstruction of Johannes Engel's table of sines in Regiomontanus's Tabulæ directionum profectionumque (1504). [Research Report] LORIA. 2021. ⟨hal-03330579⟩
47 Consultations
157 Téléchargements
