Supplementary material to the paper The VoicePrivacy 2020 Challenge: Results and findings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The VoicePrivacy 2020 Challenge focuses on developing anonymization solutions for speech technology. This report complements the summary results and analyses presented by Tomashenko et al. (2021). After quickly recalling the challenge design and the submitted anonymization systems, we provide more detailed results and analyses. First, we present objective evaluation results for the primary challenge metrics and for alternative metrics and attack models, and we compare them with each other. Second, we present subjective evaluation results for speaker verifiability, speech naturalness, and speech intelligibility. Finally, we compare these objective and subjective evaluation results with each other.
VoicePrivacyCSL_paper_report_hal2_.pdf (5.88 Mo) Télécharger le fichier
hal-03335126 , version 1 (06-09-2021)
hal-03335126 , version 2 (11-09-2021)
hal-03335126 , version 3 (13-10-2021)
hal-03335126 , version 4 (19-11-2021)
hal-03335126 , version 5 (20-11-2021)
hal-03335126 , version 6 (26-09-2022)
  • HAL Id : hal-03335126 , version 3
Natalia Tomashenko, Xin Wang, Emmanuel Vincent, Jose Patino, Brij Mohan Lal Srivastava, et al.. Supplementary material to the paper The VoicePrivacy 2020 Challenge: Results and findings. 2021. ⟨hal-03335126v3⟩
804 Consultations
126 Téléchargements
