Moving-Platform Pose Estimation for Cable-Driven Parallel Robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cable-Driven Parallel Robots (CDPRs) are parallel robots with rigid links replaced by cables. As for most parallel robots the determination of the analytical solutions to the direct geometrico-static model (DGSM) is a difficult task that is often not feasible online. However, the knowledge of the moving-platform (MP) pose is necessary in order to control the CDPR, e.g. with visual servoing. When the MP pose measurement is not available, an estimation can be sufficient. This paper compares three estimation methods: (a) controlbased; (b) image-based; and (c) model-based. The three methods are implemented experimentally with an open-loop velocity controller and a closed-loop visual servoing controller. Overall, very good results are shown with model-based and controlbased methods for both controllers. Finally, it is shown that the visual servoing controller leads to a better accuracy of the robot than the velocity controller.
IROS2021_Zake_Chaumette_Pedemonte_Caro_HAL.pdf (3.37 Mo) Télécharger le fichier
hal-03335292 , version 1 (06-09-2021)
  • HAL Id : hal-03335292 , version 1
Zane Zake, François Chaumette, Nicolò Pedemonte, Stéphane Caro. Moving-Platform Pose Estimation for Cable-Driven Parallel Robots. IROS 2021 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Sep 2021, Prague, Czech Republic. pp.1-8. ⟨hal-03335292⟩
149 Consultations
154 Téléchargements
