The isothermal limit for the compressible Euler equations with damping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We consider the isothermal Euler system with damping. We rigorously show the convergence of Barenblatt solutions towards a limit Gaussian profile in the isothermal limit γ → 1, and we explicitly compute the propagation and the behavior of Gaussian initial data. We then show the weak L 1 convergence of the density as well as the asymptotic behavior of its first and second moments. Contents 1. Introduction 1 2. Assumptions and main results 3 3. The limit γ → 1 of Barenblatt's solutions 6 4. Gaussian solutions 9 5. Evolution of certain quantities 10 6. Convergence 15 7. Conclusion 17 References 17
Barenblatt.pdf (466.75 Ko) Télécharger le fichier
hal-03335294 , version 1 (06-09-2021)
hal-03335294 , version 2 (08-09-2021)
  • HAL Id : hal-03335294 , version 1
Quentin Chauleur. The isothermal limit for the compressible Euler equations with damping. 2021. ⟨hal-03335294v1⟩
226 Consultations
113 Téléchargements
