A Flexible and Portable Real-time DVB-S2 Transceiver using Multicore and SIMD CPUs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Software implementation of digital communication systems is more and more used in different contexts. In the case of satellite communication standards, they are an appealing alternative in ground stations. The challenge is to push the performance of these digital communication systems to meet the real time constraints. In this paper, we propose an open source digital communication transceiver that enables to exploit the parallelism of general purpose processors (multicore, SIMD). It is also flexible, supporting several modulation and coding schemes. Finally, it is portable, being able to adapt to the level of parallelism of different CPU architectures (x86 and ARM).
article.pdf (178.02 Ko) Télécharger le fichier
hal-03336450 , version 1 (07-09-2021)
hal-03336450 , version 2 (20-10-2021)
  • HAL Id : hal-03336450 , version 1
Adrien Cassagne, Mathieu Leonardon, Romain Tajan, Camille Leroux, Christophe Jégo, et al.. A Flexible and Portable Real-time DVB-S2 Transceiver using Multicore and SIMD CPUs. ISTC 2021: 11th IEEE International Symposium on Topics in Coding, Aug 2021, Montréal, Canada. ⟨hal-03336450v1⟩
183 Consultations
1316 Téléchargements
