Causal-Consistent Replay Reversible Semantics for Message Passing Concurrent Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fundamenta Informaticae Année : 2021
Causal-consistent reversible debugging is an innovative technique for debugging concurrent systems. It allows one to go back in the execution focusing on the actions that most likely caused a visible misbehavior. When such an action is selected, the debugger undoes it, including all and only its consequences. This operation is called a causal-consistent rollback. In this way, the user can avoid being distracted by the actions of other, unrelated processes. In this work, we introduce its dual notion: causal-consistent replay. We allow the user to record an execution of a running program and, in contrast to traditional replay debuggers, to reproduce a visible misbehavior inside the debugger including all and only its causes. Furthermore, we present a unified framework that combines both causal-consistent replay and causal-consistent rollback. Although most of the ideas that we present are rather general, we focus on a popular functional and concurrent programming language based on message passing: Erlang.
paper.pdf (446.29 Ko) Télécharger le fichier
hal-03338674 , version 1 (09-09-2021)
Ivan Lanese, Adrián Palacios, Germán Vidal. Causal-Consistent Replay Reversible Semantics for Message Passing Concurrent Programs. Fundamenta Informaticae, 2021, ⟨10.3233/FI-2021-2005⟩. ⟨hal-03338674⟩
14 Consultations
127 Téléchargements
