A Simplified Benchmark for Non-ambiguous Explanations of Knowledge Graph Link Prediction using Relational Graph Convolutional Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2021
Relational Graph Convolutional Networks (RGCNs) identify relationships within a Knowledge Graph to learn real-valued embeddings for each node and edge. Recently, researchers have proposed explanation methods to interpret the predictions of these black-box models. However, comparisons across explanation methods is difficult without a common dataset and standard evaluation metrics to evaluate the explanations. In this paper, we propose a method, including two datasets (Royalty-20k and Royalty-30k), to benchmark explanation methods on the task of explainable link prediction using Graph Neural Networks. We report the results of state-of-the-art explanation methods for RGCNs.
paper326.pdf (196.39 Ko) Télécharger le fichier
hal-03339562 , version 1 (09-09-2021)
hal-03339562 , version 2 (07-10-2021)
hal-03339562 , version 3 (18-11-2021)
  • HAL Id : hal-03339562 , version 2
Nicholas Halliwell, Fabien Gandon, Freddy Lecue. A Simplified Benchmark for Non-ambiguous Explanations of Knowledge Graph Link Prediction using Relational Graph Convolutional Networks. International Semantic Web Conference, Oct 2021, Troy, United States. ⟨hal-03339562v2⟩
Collections
3IA-COTEDAZUR ANR
296 Consultations
109 Téléchargements
