Quantifier Simplification by Unification in SMT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Quantifier reasoning in SMT solvers relies on instantiation: ground instances are generated heuristically from the quantified formulas until a contradiction is reached at the ground level. Current instantiation heuristics, however, often fail in presence of nested quantifiers. To address this issue we introduce a unification-based method that augments the problem with shallow quantified formulas obtained from assertions with nested quantifiers. These new formulas help unlocking the regular instantiation techniques, but parsimony is necessary since they might also be misguiding. To mitigate this, we identify some effective restricting conditions. The method is implemented in the veriT solver, and tested on benchmarks from the SMT-LIB. It allows the solver to prove more formulas, faster.
frocos2021.pdf (387.89 Ko) Télécharger le fichier
hal-03341368 , version 1 (10-09-2021)
Pascal Fontaine, Hans-Jörg Schurr. Quantifier Simplification by Unification in SMT. FroCos 2021 - 13th International Symposium on Frontiers of Combining Systems, Sep 2021, Birmingham, United Kingdom. pp.232-249, ⟨10.1007/978-3-030-86205-3_13⟩. ⟨hal-03341368⟩
85 Consultations
222 Téléchargements
