AskoR, A R Package for Easy RNASeq Data Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
For facilitating the process of transcriptomics data, and to guarantee the reproducibility of our analyses, we developed AskoR, which is a R library for performing a suite of statistical analysis and graphical output from gene expression data obtained by sequencing (RNA-Seq). From raw counts, it makes it possible to filter and normalize the data, to check the consistency of the samples, and to carry out differential expression tests, GO terms enrichments, and clusters of co-expression, with a large number of figures in the output. AskoR can be downloaded and used in your favorite R environment or directly accessible through a Galaxy portal like the one which is hosted by the BioInformatics Platform for the Agroecosystems Arthropods (BIPAA).
Alves Carvalho.pdf (584.59 Ko) Télécharger le fichier
hal-03347665 , version 1 (02-06-2022)
Paternité
Susete Alves Carvalho, Kévin Gazengel, Anthony Bretaudeau, Stéphanie Robin, Stéphanie Daval, et al.. AskoR, A R Package for Easy RNASeq Data Analysis. IECE 2021 - 1st International Electronic Conference on Entomology, Jul 2021, Virtual, France. pp.1-8, ⟨10.3390/IECE-10646⟩. ⟨hal-03347665⟩
191 Consultations
187 Téléchargements
