Distributed Computability: A Few Results Masters Students Should Know - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM SIGACT News Année : 2021
As today Informatics is more and more (driven) eaten by its applications, it becomes more and more important to know what can be done and what cannot be done. For a long time now, this is well known in sequential computing. But today the world becomes more and more distributed, and consequently more and more applications are distributed. As a result, it becomes important, or even crucial, to understand what is distributed computing and which are its power and its limits. This article is a step in this direction when looking from an agreement-oriented fault-tolerance point of view.
Minimum-to-known-2021.pdf (165.54 Ko) Télécharger le fichier
hal-03347869 , version 1 (17-09-2021)
Michel Raynal. Distributed Computability: A Few Results Masters Students Should Know. ACM SIGACT News, 2021, 52 (2), pp.92-110. ⟨10.1145/3471469.3471484⟩. ⟨hal-03347869⟩
46 Consultations
153 Téléchargements
