Discrete logarithms in quasi-polynomial time in finite fields of fixed characteristic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the American Mathematical Society Année : 2022
We prove that the discrete logarithm problem can be solved in quasi-polynomial expected time in the multiplicative group of finite fields of fixed characteristic. More generally, we prove that it can be solved in the field of cardinality $p^n$ in expected time $(pn)^{2\log_2(n) + O(1)}$.
dlp.pdf (513.33 Ko) Télécharger le fichier
hal-03347994 , version 1 (17-09-2021)
Thorsten Kleinjung, Benjamin Wesolowski. Discrete logarithms in quasi-polynomial time in finite fields of fixed characteristic. Journal of the American Mathematical Society, 2022, 35, pp.581-624. ⟨10.1090/jams/985⟩. ⟨hal-03347994⟩
97 Consultations
140 Téléchargements
