Permeation and trapping of hydrogen in Eurofer97 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nuclear Materials and Energy Année : 2021
Diffusion and trapping of hydrogen isotopes in fusion materials need to be fully described in order to evaluate permeation and retention in fusion reactors walls and breeding blankets. Hydrogen gas permeation experiments have been conducted on Eurofer97 with pressures ranging from 10 1 to 10 5 Pa and temperatures between 473 K and 673 K, resulting in solubility K(T) (mol.m −3 .Pa −1/2)= 1.76 • 10 −1 exp ! − 0.27 (eV) /k B T " , diffusivity D(T) (m 2 .s −1) = 2.52 • 10 −7 exp ! − 0.16 (eV) /k B T " and permeability Φ(T) (mol.m −1 .Pa −1/2 .s −1) = 4.43 • 10 −8 exp ! − 0.43 (eV) /k B T ". Trapping parameters have been investigated using thermal desorption spectrometry of deuterium-loaded samples coupled with parametric optimization, leading to detrapping energies
Matériaux
Permeation and trapping of hydrogen in Eurofer97_revised.pdf (700.77 Ko) Télécharger le fichier
hal-03355595 , version 1 (27-09-2021)
F. Montupet-Leblond, L. Corso, M. Payet, Rémi Delaporte-Mathurin, E. Bernard, et al.. Permeation and trapping of hydrogen in Eurofer97. Nuclear Materials and Energy, 2021, 29, pp.101062. ⟨10.1016/j.nme.2021.101062⟩. ⟨hal-03355595⟩
61 Consultations
197 Téléchargements
