Analysis of Work Stealing with latency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2021
We study the impact of communication latency on the classical Work Stealing load balancing algorithm. Our paper extends the reference model in which we introduce a latency parameter. By using a theoretical analysis and simulation, we study the overall impact of this latency on the Makespan (maximum completion time). We derive a new expression of the expected running time of a bag of independent tasks scheduled by Work Stealing. This expression enables us to predict under which conditions a given run will yield acceptable performance. For instance, we can easily calibrate the maximal number of processors to use for a given work/platform combination. All our results are validated through simulation on a wide range of parameters.
WS_JPDC.pdf (553.16 Ko) Télécharger le fichier
hal-03356234 , version 1 (27-09-2021)
Nicolas Gast, Mohammed Khatiri, Denis Trystram, Frédéric Wagner. Analysis of Work Stealing with latency. Journal of Parallel and Distributed Computing, 2021, 153, pp.119-129. ⟨10.1016/j.jpdc.2021.03.010⟩. ⟨hal-03356234⟩
105 Consultations
243 Téléchargements
