Inferring the Localization of White-Matter Tracts using Diffusion Driven Label Fusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Inferring which pathways are affected by a brain lesion is key for both pre and post-treatment planning. However, many disruptive lesions cause changes in the tissue that interrupt tractography algorithms. In such cases, aggregating information from healthy subjects can provide a solution to inferring the affected pathways. In this paper, we introduce a novel label fusion technique that leverages diffusion information to locate brain pathways. Through simulations and experiments in publicly available data we show that our method is able to correctly reconstruct brain pathways, even if they are affected by a focal lesion.
Diffusion_Driven_Label_Fusion.pdf (896.61 Ko) Télécharger le fichier
hal-03360544 , version 1 (30-09-2021)
hal-03360544 , version 2 (01-10-2021)
  • HAL Id : hal-03360544 , version 1
Guillermo Gallardo, Gaston Zanitti, Mat Higger, Sylvain Bouix, Demian Wassermann. Inferring the Localization of White-Matter Tracts using Diffusion Driven Label Fusion. 2021. ⟨hal-03360544v1⟩
59 Consultations
42 Téléchargements
