Interactions between active tectonics and gravitational deformation along the Billecocha fault system (Northern Ecuador): Insights from morphological and paleoseismological investigations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of South American Earth Sciences Année : 2021
The Billecocha plateau (4000 m a.s.l.) lies in the high elevation Ecuadorian Andes volcanic arc. It overhangs by 2000 m above the interandean valley. Both the plateau and surrounding volcanoes are heavily affected by active faulting characterized by straight, sharp and discontinuous scarps within a 6 km wide and 24 km long corridor. Contrasting interpretations have been proposed to explain the expression at surface of the so-called Billecocha fault system (BFS), from normal faulting related to postglacial elastic rebound or gravitational processes, to right-lateral faulting compatible with the North-Andean Sliver tectonic regime. The instrumental seismicity recorded around the BFS is low, however, a M~7 earthquake heavily struck the region in 1868. With the aim to discuss the kinematic and coseismic nature of the encountered deformations as well as the seismogenic character of the BFS, we performed (1) morphological analysis to map and quantify evidence of active faulting and (2) paleoseismological investigations across the longer segment of the fault system. In three trenches, we show that surface deformations are at least partly coseismic in origin during the Holocene with a minor lateral component, the last paleoseismic event being compatible in date with the 1868 earthquake. In addition, some of the enlightened paleoseismic events could have occurred in relationship with volcanic eruptions of the surrounding volcanoes. While field evidence of reverse and strike slip faulting suggests that regional tectonics could be involved, the geomorphological signature of the BFS at the mountain scale, as seen on the digital surface model, can partly be related to the development of deep seated gravitational deformations, hence suggesting an interaction between boundary (i.e. tectonic, volcanic) and body forces (i.e. gravity, post-glacial rebound). Further studies are however mandatory to better address the influence of each process at the BFS, in particular geodetic and seismological surveys. Given the available data, we suggest that the BFS could actually correspond to the distributed surface expression of the tectonic reactivation of the inherited Pujilí suture, enhanced by gravitational phenomenon. In this light, paleoearthquakes identified along the BFS may help evidencing the recurrence of major events in the region. However, it also imply that surface deformations along the BFS shall not be used without a careful and more detailed field work to derive fault slip rates for seismic hazard calculations.
0000172989_007.PDF (12.33 Mo) Télécharger le fichier
hal-03360612 , version 1 (30-09-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Herve Jomard, Diana Saqui, Stephane Baize, Alexandra Alvarado, Benjamin Bernard, et al.. Interactions between active tectonics and gravitational deformation along the Billecocha fault system (Northern Ecuador): Insights from morphological and paleoseismological investigations. Journal of South American Earth Sciences, 2021, 111, pp.103406. ⟨10.1016/j.jsames.2021.103406⟩. ⟨hal-03360612⟩
50 Consultations
48 Téléchargements
