Pyramid-based Scatterplots Sampling for Progressive and Streaming Data Visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2022
Xin Chen
  • Fonction : Auteur
Jian Zhang
  • Fonction : Auteur
  • PersonId : 1087571
Jean-Daniel Fekete
Yunhai Wang
  • Fonction : Auteur correspondant
  • PersonId : 1111891
Connectez-vous pour contacter l'auteur
We present a pyramid-based scatterplot sampling technique to avoid overplotting and enable progressive and streaming visualization of large data. Our technique is based on a multiresolution pyramid-based decomposition of the underlying density map and makes use of the density values in the pyramid to guide the sampling at each scale for preserving the relative data densities and outliers. We show that our technique is competitive in quality with state-of-the-art methods and runs faster by about an order of magnitude. Also, we have adapted it to deliver progressive and streaming data visualization by processing the data in chunks and updating the scatterplot areas with visible changes in the density map. A quantitative evaluation shows that our approach generates stable and faithful progressive samples that are comparable to the state-of-the-art method in preserving relative densities and superior to it in keeping outliers and stability when switching frames. We present two case studies that demonstrate the effectiveness of our approach for exploring large data.
sampling.pdf (9.31 Mo) Télécharger le fichier
Format : Figure, Image
Licence : CC BY NC - Paternité - Pas d'utilisation commerciale
hal-03360776 , version 1 (01-10-2021)
Xin Chen, Jian Zhang, Chi-Wing Fu, Jean-Daniel Fekete, Yunhai Wang. Pyramid-based Scatterplots Sampling for Progressive and Streaming Data Visualization. IEEE Transactions on Visualization and Computer Graphics, 2022, 28 (1), pp.593-603. ⟨10.1109/TVCG.2021.3114880⟩. ⟨hal-03360776⟩
150 Consultations
240 Téléchargements
